Can you put RSX Gauge Cluster into 92-95 civic with modifications, searched
Can you put an RSX gauge cluster into an EG or 92-95 civic. I've searched and have not found an answer to it.
Re: Can you put RSX Gauge Cluster into 92-95 civic with modifications, searched
is this a serious question of course you can put RSX Gauge Cluster into 92-95 civic with modifications thats why its called custom you need to find the pinouts for both clusters
is not that easy tho it won't work right if you have a d,h, or b series in you car.
Well, yea, you CAN do it. Hell, you could put a ford cluster in there if you really wanted to.
The tricky part is making it look like its supposed to be there.
So let me take a guess at this, so all you have to do is chop the pigtails on your current speedo and wire them together with the pigtails you get with the rsx cluster. Then you need the speedo healer to get the speedo to show the correct speed. Is there anything else you need? Does the water temp work.... or do you need the modifrier? Gas gauge works and tach works with just wiring up your pigtails?
KustomCrx
02-04-2017 08:12 PM
H22a_n_91civic
23
10-01-2004 01:18 PM
