gsr into ek need help
i have a 1997 ek hatch and i am getting an 1999 gsr swap and my question is what harness do i use and what computer thanks
Re: gsr into ek need help
from what i have researched use the factory harness that is in your car already and wire it up accordingly as for the ecu use the ecu from the integra if you plan on staying with a plug and play ecu both are obd2a -
i just got my gsr swap done last month everything is good except for 1 cel code which i should have fixed today You will use your civic harness the gsr p72 ecu you will have to run 1 wire for the knock sensor and 2 wires for the iab's 2 wires for vtec wire a second o2 sensor heres some write ups i found when i was doing my swap
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/gsr-into-ek-wiring-using-obd2a-2488755/
http://images.google.com/imgres?imgu...0byeTwBvrT5cgL
so i need my stock harness and a p72 computer i was wondering if i can use the 2000 si harness and the si computer of the 2000 si for this
MiG-21 superfan
here is the hybrid subforum - https://honda-tech.com/forums/hybrid-engine-swaps-18/
here is one of the stickies that has alot of info - https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A%2A%2Aokay-lets-cut-down-repeated-qs-about-certain-swaps-post-links-here%2A%2A%2A-650230/
but there is good info everywhere in that subforum.
Mr. KDes
12-30-2013 01:50 PM
BMacls
05-10-2003 05:36 PM
