A/C question
A/C question
I recently bought a 1995 ex civic, when i press the a/c button i dont hear the click or the compressor clutch kick in..usually when you press the a/c button your idle will go down then up but mine doesnt..can anyone give me advice on what to check so i can fix it? hopefully its not the compressor but just a relay..thanks in advance
Re: A/C question
-switch the relay, the one by the driver head light, if your fan still turns on, then ur relay is still good, if not then you have a bad relay
-check if you havc enough freon
-i had this problem with my car, and 1 of the 2 wire was broken where the wire connects to the compressor, you can't see it unless you take off the little screw that's covering it on the compressor.
