B20 EG Hatch ignition problem
Hey H-T, i need your help. I have a 93 EG Hatch with a B20 swap Gsr Heads on it, problem is this. The car has a G5 alarm and when i go to turn it on sometimes it turns on, sometimes it doesnt even crank over, and when that happens i have to push start it. What can be the problem?
Re: B20 EG Hatch ignition problem
check your ignition wiring for a kinked or exposed wire. That might explain why it would only work sometimes. I would "play" with the wiring while its trying to start to see if it fires up then. If not, then do the basics such as checking the plugs wires and dizzy
ceeejay
02-02-2005 09:28 PM
zanthrax
Audio / Security / Video
11-24-2003 02:53 AM
