del sol help
del sol help
ok so i bought an 2000 ek shell that had a z6 motor in it.. and i am wanting to drop the z6 in my sol and am wondering what parts i need.. right now i know i am needing the motor harness.. am i going to need a different tranny mount too??? and the ek was running a p2p ecu can i use that with the sol or no?? lmk what all i will need guys if yal can.. i already pulled the motor out of the shell.. pulled the shift linkages and axles
Re: del sol help
What year Sol? The later ones were OBD2. You won't need any different mounts, other than what was on the motor in the Sol before. Depending on the year the Sol was made, you may be able to make the ECU work. The last Sols were OBD2A, but your ECU is OBD2B. I don't know if you could repin your plugs or get a adapter harness.
Re: del sol help
the sol is a 94 i believe... i think they are obd1 that year.. and yeah i figured i might need to get the jumper harness.. or would it be easier to just get like a p28 ecu or somehting like that
Re: del sol help
Yeah, a P28 would be better. Any OBD1 Civic/Integra ECU can be used, if you modify it, plus if you swap down the road you'll have something ready to tune on. Depends what you want to do. A P28 can always be sold easy and chipped later.
Re: del sol help
if i did use the p2p ecu what jumper harness would i need?? be the obd2b to obd1 harness right or wrong?? thnx for the help so far guys
gsrboost737
03-11-2010 06:58 PM
94delsoltypeR
11
08-15-2007 06:57 AM
