b18b1 swap eg clutch problem
i cant bleed the clutch on my ls swap in my ej i bought a new slave cylinder and put it on fluid goes through ive tried bleeding it but the clutch pedal still does not get pressure anyone kno anything bout this
Re: b18b1 swap eg clutch problem
hey did you replace a line 2 keep trying took me about 4 hrs to do mine in my h22 swap eg cuz i ran all new line it sucked keep trying just use ur hand so u can pull it back up i bet there is a mega amount of ari in it
also i forgot to add that every time i pump the clutch pedal the slave cylinder/ throwout bearing does not pump!! ive tried pumping it from the slave/throwout bearing but still gets no pressure!
