Transmission Swap
Transmission Swap
Will all the swap parts off of an EK Civic fit into an EG Civic? I'm pretty damn sure some things like the hydraulic lines are not the same. I am not sure about other things like the pedals and such.
Re: Transmission Swap
I know for sure, the tranny, clutch/flywheel will fit. Pedals, I'm gonna GUESS, they will, but not 100% sure. The lines will also fit, but may not be completely aligned, but they will bolt up and function correctly.
318 Curves, 11 miles
A lot depends on which engine/car you're talking about.
The driver's side engine mounts are different. Throttle cables are sometimes different.
For example, I just helped throw a y8 from an EK into a 94 CX. We had to swap out the driver's side mount, the throttle cable, and add vtec wiring. Think clutch slave, shift linkage, were kept from the EG. Rest of the engine mounts I think were used from the EK.
Are you talking about a D swap or a B swap?
