Del Sol Auto to 5sp help
I got this del sol thats an auto, and Im wanting to convert to 5sp..as of right now I don't have the tranny (and mounts) and linkage..will i need axels for that tranny? (if so i got them too)..but what else would i need? ecu, throttle cable, pebals, master cyclinder for the clutch and clutch lines? do i need 5sp wiring harness?? is this conversion even worth it? plan to boost the d series, thats why im wanting to convert
Re: Del Sol Auto to 5sp help
Just need the trans, linkage, pedal set, run the appropriate wires from the auto shifter to the clutch pedal switch, and you can convert a auto ecu to manual by cutting rp17 and bridging rp18. It makes the ecu into a manual ecu.
And if you don't already know, you either have to cut the chassis mount out for the transmission and weld in a 5 speed mount, or get one of the conversion mounts that replaces the regular motor mount. It's $100-130 whether you get Avid or Hasport.
I think there's a reverse light and wire that signals that it's in park that has to be run to the clutch pedal switch. I cannot tell you offhand, but there's a plug and each wire gets run somewhere else.
This link here shows where they go.
http://www.hondacivicforum.com/forum...version-31774/
Get the clutch pedal set and just the manual brake pedal. Unbolt the auto brake pedal and bolt in the manual one. That way you don't need a new throttle cable.
You'll need to make a cover for the shifter hole. A new oem shift boot is approximately 10 bucks from your dealer and will fit the automatic console just fine.
sfarrell12
05-25-2008 11:10 PM
