water got in my motor-_-...whats an ok engine swap?
hey guys i have a 95 eg 4door with a d15b7 and it had a cooling problem so it just overheated and water is all in my oil now...what is a good replacement motor that wouldnt require me to do any major replacements like cpu or trans? i really dont have the money to do alot right now and this is my only form of transportation so i would like to do the least i possibly can. i know it sounds cheap but i have plans for this car thats y i havent sold it . any reponse good or bad will be fine.
Re: water got in my motor-_-...whats an ok engine swap?
no the engine didnt seize up but it doesnt turn on at all it cranks and sounds like it want to turn on but it doesnt start up.can i just replace the heads? since i can see the oil is all brown and mushy in there.
Seagull Management
Dual Carbed JDM D15B, reuse your intake and exhaust manifolds as well as the distributor. You'll also need to remove the mechanical fuel pump bolted to the back of the head and replace it with a cover.
so it would be better to just replace the heads or get em redone?
ive had LOTS of problems with this car but i wanna keep it as my project but im just going to start work again so i need to know whats better replace or rebuild?
Ehron
08-19-2002 12:58 PM
