any idea where my coolant is going?
Old 06-06-2011, 06:08 PM
snibbor's Avatar
Default any idea where my coolant is going?
Hey everybody...today i changed my heater hose because my old one got a few holes in it and was over-heating anyways..i fixed it and now the car isn't over heating or anything...but everytime I put coolant in the reservoir theres no leak but after i drive and come home and go to leave again its empty...and theres no leaked coolant anywhere...any idea?
motor is a boosted d16y7 if that matters
Old 06-06-2011, 06:17 PM
Former User's Avatar
Default Re: any idea where my coolant is going?
Did you bleed the cooling system after replacing the heater hose?
Old 06-06-2011, 06:30 PM
snibbor's Avatar
smh... no sir, i didn't know i had to do that..how do i go about that?
Old 06-06-2011, 06:32 PM
Bleeding the cooling system may take 20-30 minutes:
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push/turn the dash heater lever/**** to MAX heat (fan does not need to be on)
3) Follow the directions in the diagram below
Old 06-06-2011, 06:57 PM
snibbor's Avatar
so do i need to use the bleed bolt?
Old 06-06-2011, 07:00 PM
A D16Y7 has no bleed bolt.
Old 06-06-2011, 07:19 PM
snibbor's Avatar
oh okay sorry! haha i've never had to do this before, why does it take 20-30 min if i just have to add coolant turn it on and off and then add coolant again? and this will just take care of the fact that my coolant keeps disappearing? haha sorry, im very new to doing it myself, but i love it
Old 06-06-2011, 07:31 PM
It takes some time to get all the bubbles out of the entire cooling system.
Old 06-06-2011, 07:49 PM
snibbor's Avatar
oh okay thank you very much sir! much appriciated
Old 06-07-2011, 09:22 AM
delsolintegra's Avatar
Check your oil dipstick to see if there is any coolant leak in to the oil.
Is your exhaust blowing white smoke?
When the engine is running does the upper radiator hose feel hard like it is pressurized?
These are signs of serious problems like a blown head gasket or cracked head or block not uncommon with Hondas especially boosted Hondas.
Old 06-07-2011, 09:40 AM
legend97's Avatar
bleed your coolant system
jxhxb
06-28-2010 05:16 PM
soclean1k_JDM
05-04-2009 09:31 PM
blumpfish
04-09-2009 11:32 PM
95dc2teg
09-24-2007 08:15 PM
Pat
01-27-2002 05:12 PM
Quick Reply: any idea where my coolant is going?
