COOL GAUGES! ------->>> Can I do IT??
2000 Civic Si
Hey would it be possible after reading wiring diagrams to put this motorcycle Gauge Cluster into my Si?
http://cgi.ebay.com/ebaymotors/LCD-d...item19c5e2d6db
Heres my reasons why I think its practicle and flow wih the Car. On my OEM Gauge Cluster the Fuel gauge itself is broken also is Engine temp. I need to get a new tach anyway because the oem shows Redline @ 8K RPM stock... my final reason is my car isnt stock. I've had it in my garage for 4 years and have been "unstocking" it. Idk I think it would look pretty cool in place of the Stock Cluster obviously molded in. My VAFCII is blue led I have a 3 Gauge Pillar that Im going to put the Colbalt Digital LED Oil TEMP, Oil Pres and Boost.
Fuel/Air Pressure are on the Vtec controler. Think it can be done?
Re: COOL GAUGES! ------->>> Can I do IT??
(connecting the two red cars speedometer rpm motor show will be twice as fast, because the two points each turn red is a fire! a red two-and four-punch is rotated to punctuate a fire!) Note: The project is a rotating two-punctuate Fire motorcycle work.
This was on the ebay page, wtf does all that mean lol
Just saying...you can get a used...working...si cluster for like 75 bucks...and a good tach that will redline where ever you want it for....
and save probably 400 bucks in fiberglass molding and 15 hours wiring....
It'd be cool...but at that point...why not just do something like a s2000 cluster....
I mean, youd prob be the first person to do this...so if your going on the show car circuit, then by all means....but just know what your getting into.
^It's not going to be as easy as you think sir. :/
edit: even 15 hours is an understatement....if you count research time...i'd give it 20+ hours for someone well experienced with wiring... and at minimum wage that's nearly enough to get you a very nice cluster. G'luck
Lol sounds like im pullin my dick around to my *** and f***in myself! This will be interesting then!
Erik_Pb_Foot
04-26-2002 09:05 PM
