EG hatch/B16A swap/JDM P30 ECU - TPS & KS codes
Ive searched and cant seem to find what I need. I have a B16A 2nd gen in my EG hatch. Im getting a TPS code and KS code. Not sure if theres a sensor there or not to be honest. Im using a harness out of a 95 GS-R and a JDM P30 ecu. For one im trying to figure out what 2 plugs on the harness go to. One im assuming is the knock sensor but the other is closer to the distributor.
The AC and power steering are not in the vehicle. Could one be for the AC?. Also the oil pressure or temp sensor next to the filter (looks like a metal nipple coming off it) Is there supposed to be a plug on there?. There isnt and I wasnt sure.
Im new to motor swaps and this is my first so im not sure what to do here.
Also while im asking questions, what would cause a clutch to sometimes catch slightly towards the floor but catch the rest of the way up further?. Slave cylinder not bled properly?.
Re: Could use some help with some sensors
Is it a yellow wire with a stripe?. If so im guessing its the wire that someone cut
Also the knock sensor is there and plugged in. Wondering if maybe theres nothing in the slot at the ecu or something.....damn this is confusin me.
Ok so I wired my knock sensor today and now it idles lower for some reason. When I step on the gas it drops idle and seems like it wants to stall. Not sure why its doing this. I wired it to pin D3 on the ECU.
T_Rex
10
09-10-2002 08:38 PM
