How much power would turbo add to the D16Z6?
Re: how much would i have if i added a turbo?
mine has about 250, depends on ur setup, how many lbs of boost you are running, and the tune and what not, mine hauls *** tho i love it, i mean its nothing compared to a hella built motor or anything but its sweet
The Grumpiest
The question you are asking is like asking "Which came first? The chicken or the egg?"
Not enough information to answer this question. You should read the Forced Induction FAQs.
Have you done any research into assembling a turbo application?
What turbo?
Stock bottom end?
What horsepower are you looking for?
Do you plan on buying quality parts or the cheapest things you can find?
What turbo?
Stock bottom end?
What turbo?
Stock bottom end?
What turbo?
Stock bottom end?
you really don't need that much power to make these cars fast i would worry about hooking up once you get the the setup on there.
The Grumpiest
"Hooking up"? They don't make that kind of power unless built and even then they probably won' be streetable. Definitely think about changing out the clutch. Even a small turbo and "mild" boost will cause the clutch to slip.
What turbo?
Stock bottom end?
What turbo?
Stock bottom end?
Re: How much power would turbo add to the D16Z6?
I hope to make around 300+ on a Vitara eagle y7/y8 mini me with jge race valves skunk 2 springs and retainers that what I have so far still gotta do alot of research before I choose what cam to use and what turbo ima go with + tune <-----(most important)
