civic lags, stalls
civic lags, stalls
98 civic lx automatic 1.6 with 144k. The top o2 sensor is wired directly to the computer. Is there a reason someone would do this or did they not know what they were doing? Is there a remedy? It runs rough and hesitates.
Re: civic lags, stalls
grumble strikes again with yet another worthless post... The upstream o2 sensor will cause driveability issues. The upstream o2 adjusts air fuel ratios and will cause hesitations, erratic idle, etc. It is possible there was a damaged wire somewhere in the harness that was cancelling the signal to the ecu. Is the check engine light on?
The Grumpiest
Whoever had the car before did some strange wiring for God knows what reason.
What ELSE is going on with this car?
When was the last time this thing had a full tuneup?
Not really enough info to start diagnosing the problem with the lack of info.
The Grumpiest
The OP needs to take care of that hack job wiring before he starts trying to diagnose problems with various parts.
And what do YOU know about H-T? You haven't been here but a hot minute.
I don't care if the ECU doesn't use the signals until a certain time. I said the sensor sends signals to the ECU so what does it matter that it's wired directly to the ECU?.
Who said anything about a wiring issue? He said the o2 sensor was rewired directly to the ecu. The wiring could be flawless for all we know. OP we need more info. it is possible your IACV is dirty and causing the drivability issues and your o2 sensor is fine...
The Grumpiest
Like I said. Fix the wiring, which INCLUDES the hacked up 02 sensor wires, and the problem will more than likely go away. If not then that's just one more thing repaired that you know is working as it was designed to.
Thank you for all of the answers. Yes, it's been tuned up, new plugs, wires, fuel injectors, timing belt, water pump and o2 sensors. The wiring is a hack job (things wired wrong and connectors not plugged in to anything) so it seems like it's a matter of redoing the wiring. I had a few techs at honda look at it but were stumped. They called an "expert" in today so I will see if he can figure it out.
bigmikey7351
06-03-2008 09:01 PM
Acura_I-RS
10-04-2003 11:32 AM
