2000 civic si - cluster and climate control lights don't work?
hey guys,
im new to this forum, sorry if its already been talked about but i could not simply find it.
my gauge cluster lights do not work nor does my climate control lights. i took off the cluster and the old owner did some hack job. i wired everything back to its stock location and still nothing.
any suggestions? i also checked fuses but idk which fuses would run the cluster and climate control?
thanks!
thanks!
Re: 2000 civic si cluster problem?
triple checked, not blown.
and the dimmer switch is all the way up, but maybe the switch is messed up?
when i bought the car it had white faced gauges and it lite up very vaguely. i took off the white face gauges and wired everything back and nothing now. but the climate control never worked.
Re: 2000 civic si - cluster and climate control lights don't work?
Use a short piece of wire or paperclip to connect the red wire terminal to the black wire terminal in the free dimmer switch connector -- just like jumping the service connector to pull CEL codes (if you have done this).
JasonYo
11-30-2009 09:21 PM
VtecCivic93
18
07-24-2009 05:31 AM
JDM_EK_wanabe
09-28-2006 02:03 PM
