Erasing error code! Help!
Old Jun 4, 2011 | 03:44 PM
DanDaMan559's Avatar
Default Erasing error code! Help!
Hey guys, I recently purchased a 99 si. I changed out the p72 ECU the previous owner had in favor of the stock si ECU. I immediately got the "check engine" light reading error code p1337, which has to do with the CFK sensor. I referred to my 96-00 service manual and the first trouble shooting step it said to take was to reset the ecm/pcm. Not sure if it was the proper thing to do but using my diagnostic scanner i erased the error code. Then i disconnected the battery for 30 min and reconnected it. There is currently no "check engine" light on. Did resetting my ecm work (doubtful) or did i simply erase it and havent actually solved anything yet... Thank you all for your help!
Old Jun 4, 2011 | 04:12 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Erasing error code! Help!
Have you driven it since then? Has the code returned?
Old Jun 4, 2011 | 04:14 PM
redm3turbo's Avatar
drive it 150 miles and see if it returns
Old Jun 4, 2011 | 05:05 PM
I've only driven it about 10 miles and it hasn't returned yet, I'll follow your advise and wait for the 150 mile mark. I just don't know too much about the CFK sensor and whether it's a critical part of the engine...
Old Jun 4, 2011 | 05:16 PM
HondaPartsHero's Avatar
Technical Hero
What engine is it? The stock B16?
Old Jun 4, 2011 | 05:29 PM
Yes it has the stock b16a2, previous owner had swapped in a h22 but put the original engine in a few months prior to me buying it. BTW, it has gsr cams, if that makes a difference.
Old Jun 4, 2011 | 06:09 PM
Former User's Avatar
Do nothing unless the CEL code returns.
Old Jun 4, 2011 | 06:14 PM
Will do, thank you guys for your help!
jchrm80
Jan 30, 2008 09:42 PM
jchrm80
Jan 30, 2008 04:27 PM
jdmazm
Apr 21, 2005 07:58 PM
IgniteTeg
Aug 8, 2002 09:26 AM
IgniteTeg
Aug 7, 2002 06:54 PM
