blowing white smoke? Needs Help ASAP
hey honda-tech users im having a problem. idk why my car is blowing white smoke, maybe white and blue-ish smoke i dont think its the head gasket cause i barely changed it and torqued the head bolts right. i notice my motor gets really hot but my temp gauge reads fine. it dont over heat. sometimes water goes down, not to where its empty tho. can it be my sensor on the thermostat housing? or is it the valve seals? does any of ya knoe or been thru what im going thru, please help me out thanks
Re: blowing white smoke? Needs Help ASAP
the head gasket did blow before tho and water got inside. u think it can be a high chance of the compression being messed up? and if it is, how would u fix it?
so did or did you not blow a headgasket prior?
After you change a Head Gasket the car is going to smoke for awhile, in some cases a long while. water is still in the exhaust and needs to burn (smoke) itself out.
Do your water hoses feel tight as if the coolant system is under abnormal pressure? typically if your HS is breached or blown you will notice the top radiator hose is bulging from too much pressure.
many ways to test, compression test is good, or the block tester stuff thats sold at parts stores. turns color if exhaust gases are in the coolant system.
ragethemachine86
10-03-2006 09:33 AM
