b&m Shortshifter install help!!!
i have a b&m shortshifter but it doesnt have anything to go inside the hole where it connects to the shift linkage the short shifter i have on now has the bearings like roller skates but the b&m's hole is too small to fit the bearing in.
anyone have pictures would be great
or was i suppose to use oem stuff?
Re: (Egone)
ok for that not 100% on this as i got the full kit with housing ....
BUT
i would say that you need to unscrew the 2 (i belive alan screws) and the insert the shifter into there then rescrew them screws in and bolt it up the same way as you took it off.
BUT
Re: (Egone)
ok after you take the shifter off the shifter bars ...
you ahve the stock shifter with the housing on the ball
take the 2 screws.. bolts... whatever they are and take them off ...
seperate the housing from the shifter bar
put in the B&M shifter bar and reverse the process
see thats the problem the guy i bought this car off used a generic SS so there were no housing but just rollerblade bearings and screws so im guessing i need the oem stuff?
Re: (Egone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Egone »</TD></TR><TR><TD CLASS="quote">see thats the problem the guy i bought this car off used a generic SS so there were no housing but just rollerblade bearings and screws so im guessing i need the oem stuff?</TD></TR></TABLE>
Ghetto install....get the oem stuff.
Re: (GTlvr82)
are u sure i need oem stuff??
because i checked out other shortshifters and they also use
the rollerblade bearings like DC etc
the b&m tho the hole is too small to fit a bearing in
Re: (Egone)
pics http://www.hondaracing.ca/inst...x.htm the second picture with the green arrow i cant seem to get the bolt to fit tight its all loose and the shifter never came with bearings
Re: (Egone)
I have a b&m ss... it doesn't have bearings... it's just a hole... you use the stock rubber on the outside of either end and pass the stock bolt through it... it should tighten up fine... you don't want it too tight to operate... but not so loose it rattles...
Mine worked fine. I don't like where it sits but that's another story.
Re: (Egone)
just so we're clear the hole is a semi snug (able to spin freely) fit on the stock bolt... it's possible that the sleeve which the bolt passes through is missing but if it looks like the pic you posted then it's correct.
