OBD1 motor in OBD2 car which O2 sensor to use??
I missed the boat
Hey guys I have a OBD1 B16A2 going into my '00 hatch and was wandering which O2 sensor plug I should use or if makes any difference. I have both plugs on the harness still and just want to get it right
I missed the boat
Re: OBD1 motor in OBD2 car which O2 sensor to use?? (acuracing)
Yeah I have the OBD1 ECU and the conversion harness. I do have one other question for you though (you might know), how do I go about switching the wires on my OBD1 distributor to fit my OBD2 plug? The OBD1 has 2 plugs and the OBD2 dist. has just one, they both have the same amount of wires but I have no idea which order they go in. Any help is greatly appreciated
1 Post
Re: OBD1 motor in OBD2 car which O2 sensor to use?? (EGCIV)
The wire colors that run from the clip to the distributor should match the wire colors on the wiring harness from your 2k civ. Damn I really need to finish my install stuff and post up those colors to match it easy. All I can say is that If you have your old motor and the new moter and both wiring harnesses then you should be able to figure out what goes where. If I can do it then.......
