how do i remove PINS from ecu connectors?
well i need to wire vtec again in the new civic and i have a set of ecu plugs i got out of the junk yard and i need tro remove the pins from the connectors so i can stick them in the civic plugs. last time i had to do i i actually cut the carefully out but itr was a pain and took forever. what is the proiper way to do it without damaging anything?
Re: how do i remove PINS from ecu connectors? (nextelbuddy)
Maybe you should try using a set of dentist's tools like a pick, the thing they use to scrape your teeth with. I have a set and it works for pulling/pushing pins out of plugs.
Use an eyeglass repiar kit. The little flat head screwdriver is small enough to pull back those llttle tabs that are attached to the pins.
Modified by tommyboy at 12:27 AM 7/30/2003
Re: how do i remove PINS from ecu connectors? (navin)
Here's a link to some Macro pics I took a while back explaining how to do it. Yeah I know I can't explain very well and am very confusing but the pics show pretty much what you are doing.
https://honda-tech.com/zerothread?id=527874
shorty91
06-25-2003 09:48 AM
