gauge cluster bezel removal 95 Civic..
i removed the 2 top screws and i can't get it out...the tabs are impossible to get out without breaking it.. any tricks to make it easier?
Re: gauge cluster bezel removal 95 Civic.. (Sean EH2)
there are also two screws behine the hazard switch and the driver side vent has a clip. as long as you get out all 4 screws, it just takes a little finesse. good luck!
Re: gauge cluster bezel removal 95 Civic.. (dogpile5)
thank you!!!!
how do you get them out! theres no way i can get a screw driver back there
u just take off the two top bolts then with a flat head go on each side and pry it off with a little force...when it pops off the clips (dont worry will make a sound u might think u broke something) then detach the hazard harness clip and the clock clip then it comes right off...lates.B
official honda whore
there are 2 screws on the top above the cluster and one behind the hazard switch
get those out, then a flat head to get the right side out and it should pop out fairly easy,
undo the clips,
then on the left side put a flat head in the middle bottom of the vents and thats where the clip is and pry up there and pull it out
undo the clips,
live4soccer7
11-03-2011 07:06 AM
allstarr7
12-18-2007 02:49 PM
tjd92accord
12-04-2005 01:54 PM
