engine is feeling weak....HELP!!!
ok i dunno whats goin on and i did a search but i have no idea where to start or search for.....the engine just seems weaker than before(stock) i havent added anything to it....when im driving normally (pedal halfway down) itll accelerate and then pulse one time.....its nothing big and im thinkin it might just be my imagination or a bump on the road, but it seems like i always feel it......and thenit just feel real weak before vtec.....affter vtec it used to be fine.....but tonight i got on it and it just didnt pull like it used to........im sorry if i cant explain this in detail just if u guys could help tell me where to start looking or what part to change id appreciate it...
thanks
thanks
Re: engine is feeling weak....HELP!!! (buda18)
to motivate responses you might want to include some specifics... maybe what kinda car, symptoms other than "feels weak", anything that might help us help you... otherwise you'll just be helpless!!
-Bryan-
-Bryan-
Re: engine is feeling weak....HELP!!! (d16-eh2)
95 gsr in 92 HB.....the only symptom there really is, is that it pulses when im just driving like not continuously but just once
Re: engine is feeling weak....HELP!!! (976)
If your feeling hesitation its probably sparl/ fweul related. What ECU are u runin? I was runin a PR3 for my GSR swap, old b16 injectors and a civic fuel line. The result was 45 miles to the gallon and some freakin BURNT spark plugs!! It ran fine for about a week and then started hesitating under slight throttle. My plugs are ruined. So... isent then ECU out to get custom chipped, got my fuel injectors rebuilt, they flow 250 cc's now all across, and bought a b series fuel line which is significantly bigger. Look at your plugs thats the first indicator. How many miles are you getin to the gallon? Are u using D series or B series fuel line?
Re: engine is feeling weak....HELP!!! (Mentat Ghola)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mentat Ghola »</TD></TR><TR><TD CLASS="quote">If your feeling hesitation its probably sparl/ fweul related. What ECU are u runin? I was runin a PR3 for my GSR swap, old b16 injectors and a civic fuel line. The result was 45 miles to the gallon and some freakin BURNT spark plugs!! It ran fine for about a week and then started hesitating under slight throttle. My plugs are ruined. So... isent then ECU out to get custom chipped, got my fuel injectors rebuilt, they flow 250 cc's now all across, and bought a b series fuel line which is significantly bigger. Look at your plugs thats the first indicator. How many miles are you getin to the gallon? Are u using D series or B series fuel line?</TD></TR></TABLE>
there is no check engine light
and it should be the gsr ecu...ill check and see which one it is
i didnt do the install and when i got the car i didnt notice this problem so im sure they tuned it a little bit or whatever...but yeah im hearin alot that its spark/fuel related ill check all that stuff u said Mentat...also do u think it could the the coil or the ignitor?
check out the fuel situation, if that is ok, then move on to the coil and ignitor, but in my opinion, its fuel related.
