ok i did the amber gauge cluster bulbs
I did the amber gauge cluster bulbs on my eg hatch [si] and my questions are when i did the bulbs i pulled all the brown socket things out..
and pulled the stock bulbs out and put the amber bulbs i did in and then i moved to the section where the fuel gauge and temp gauges are
and one of the bulbs didnt want to go in..for some reason i think it might be a different size?
does anyone know if they are? so now the rpm section lights up amber and my mph section lights up amber and the fuel and temp section lights up white...i gotta fix this...when i get done with the final product ill write a HOW TO and take some pics.
Re: ok i did the amber gauge cluster bulbs (USDMDC2)
on my 93 si hatch....i did the amber light change also....several of the bulbs were very tight....don't know why, but i used the same size bulbs in all the slots...i remember there were ( 2 ) holes that were so tight i couldn't squeeze the bulb in, cuz i was afraid of shattering it....so i took a round file and just kind of wallered out the hole alittle bit, and then they went in fine.
Re: ok i did the amber gauge cluster bulbs (MIRRAdekhtc)
i did it to my hatch too you can check it out here https://honda-tech.com/zerothread?id=454449 i believe theres 6 or 7 bulbs in total tha light up your cluster(im not too sure what the total # of bulbs is) almost all of them are size 24NA and one is i believe size 74.i hope that helps!
Re: (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">where can you get the bulbs at and how much are they?</TD></TR></TABLE> My question exactly! AutoRice doens't carry them.
zer0Limitz
11
09-13-2019 06:42 PM
fakemike
76
10-01-2002 06:55 AM
