Z6 engine not running after multiple repairs check it out!
Z6 engine not running after multiple repairs check it out!( FIXED)
ok so my z6 was running before i decided to change out my rear main seal. found out my dizzy was leaking so i got that sealed up. changed vtec seals because i had them. tried to start my car and nothing. checked spark and fuel its all there. i thought it may be flooded but i cleaned the plugs and let the cylendars dry out a bit then last try it backfires out of the intake manifold. read it could be the timing is advanced but the car has to be running to fix the timing right? what do you guys think this could be?
PHANTOM MENACE
Re: Z6 engine not running after multiple repairs check it out!
To set the ignition timing properly the car has to be running BUT it doesn't need to be running to simply adjust the timing. So now the question is did you mark the distributor before removing it to replace the o ring?
Also check the fuse panel for "starter signal" and see if that is good. I only mention that because you say you've got spark and fuel and I doubt that what you did killed compression.
maybe the dizzy is on backwards, I guess that's possible for some people??? definitely should have marked that before disassembling, also did you put it back together correctly if you replaced the internal seal?
2 pronged drive? do you got a picture to show because im lost. I was thinking it was probably something inside the dizzy but like I said I put it back together how it came apart or maybe it wasn't gapped or to gapped between the shaft pickups.
blue where it sparks and then white on the arc so yea more white, mechanical timing as the dizzy or jumped a tooth? I think maybe dizzy because I didn't mark it where it was previously running and swapped the guts and now it cranks and sparks and fuel is getting to the head but sometimes backfires out the intake. ive torn the dizzy down and replaced the igniter and checked gaps between the pickups and still nothing.
Seagull Management
Yeah, remove the snap ring, slide the pin out, turn the two pronged drive 180° and reassemble. The drive itself will only go into the head one way, the two prongs are offset a little bit to one side.
I see what your saying but the dizzy will still mount either way just off time?
Line up the timing marks on the cam sprocket and crank pulley. Pull the dizzy cap off and see which cylinder the rotor is pointing to as if it was going to fire.
ok, now the crank pulley has been replaced is there anyway if I were to line up the pulley with the cam gear the marks wouldn't be right? if that makes any sense?
PHANTOM MENACE
The main pulley can only be installed one way. If you haven't touched the timing belt or tensioner then the crankshaft and camshaft should still be in sync with one another (meaning main pulley and cam gear should still be aligned properly to one another).
Now if you find it has moved, you will need to reset your mechanical timing and go from there. If it has moved enough it would explain why your car isn't starting. I sincerely doubt it has moved/jumped a tooth but you never know.
