speedometer problem
Old Nov 28, 2013 | 08:14 AM
Jameel Anan's Avatar
Default speedometer problem
hey guys...my speedometer doesn't move at all...and when i start the car and drive for about 10-15 mins the check engine light is on...any relation between them ??
Old Nov 28, 2013 | 08:33 AM
aaron96civic's Avatar
Default Re: speedometer problem
My speedometer in my 96 Civic has been intermittent for about 4 years. Sometimes it works, sometimes it doesn't. Overall I'd say it works 30% of the time. I've never seen my check engine light on since the speedometer quit working correctly. Not sure if the check engine light has any correlation with your speedo not working.
Old Nov 28, 2013 | 09:14 AM
thx for info...actually 3 weeks ago it started to play and not measure right...i mean working but not right..1 week ago it stopped compeltley and the check engine begun to show
Old Nov 28, 2013 | 09:43 AM
24TEN's Avatar
PHANTOM MENACE
I believe a non functional speedo (meaning no signal) triggers a check engine light after a certain speed is reached/exceeded. Can't say for certain BUT instead of speculating why don't you just see what the check engine light is for?
Old Nov 28, 2013 | 05:43 PM
andre3wap's Avatar
Maybe the speed sensor is bad? it happened to me on my 98 civic coupe. I had to replace the sensor, then it worked fine.
Old Nov 29, 2013 | 06:03 AM
can u tell me where the sensor is ??
Old Nov 29, 2013 | 06:36 AM
Former User's Avatar
Tech threads MUST mention car and engine information.
Pull the CEL code and post it. Click the codes link in my signature.
Old Nov 29, 2013 | 08:48 PM
24TEN's Avatar
PHANTOM MENACE
It's on the back of the transmission above the differential area. It should be the only thing with an electrical connection on the back side of the transmission.
Old Nov 29, 2013 | 09:28 PM
Tyler Dirden's Avatar
I am Jack's...
Buy one off eBay (speed sensor) to save a crap load of money. Their over $100 in part stores. It's where He said^^^^, reading the output shaft rotation and converting it to pulses for speedo,cruise etc.. They go bad alot. I have changed 3 in 5 of my Hondas.
The sensor has three wires (red,blueyellow).
Old Nov 30, 2013 | 05:44 AM
thx alot
Old Nov 30, 2013 | 05:45 AM
i'll do that...thx
Eg_hatch_95
Mar 15, 2009 10:35 PM
KrenzyRyan
33
Aug 1, 2007 03:08 PM
pat671
Nov 12, 2006 08:01 PM
c.dub
Mar 6, 2005 08:49 PM
originalbadbob
Jun 24, 2004 10:17 PM
