97 Civic Auto Trans issues
I just purchased a 97 civic, not sure what model exactly but it is auto and has the d16b5. Anyways, the trans is acting up. It has all gears and no CEL or anything but when you select a gear the vehicle won't go into gear until you blip the throttle, sometimes banging into gear if you do anything more than 'blip' the throttle.
Also besides the issue above the car will drive fine if manually shifting through 1st and 2nd but if I just leave the car in drive the car will sometimes shut off at low speeds or when coming to a stop.
I don't know much about auto transmissions but I am trying to pinpoint if I actually need a new trans or if it could be a smaller problem. I did unplug what I believe to be two solenoids on the transmission and there was no difference in how the vehicle reacted.
Any help?
Any help?
I haven't yet, just dropped the car off last night but my plan was to replace the fluid first and see if it continues but is this type of issue possibly one of the solenoids if that doesn't work?
Also what's the best fluid to use with the auto trans? Still GM syncromesh?
I never narc'd on nobody!
Re: 97 Civic Auto Trans issues
Honda OEM fluid. Do a 3x drain/fill. It sounds like you have a torque converter problem. A 3x drain/fill will get you fresh fluid throughout the transmission, including the torque converter where fluid will stay "hidden" if you only drain/fill once. Do not flush the transmission. You'll only kick up particles in the microfilters and cause more harm than good.
Side note: The D16B5 is from the GX, which was made to run on CNG. Did you buy a GX, or something that was swapped? Assuming you're feeding it 87, how's it liking it?
I'll have to check the title, what is a GX model? What is CNG? I was told the car was swapped but the motor looks original. I put 87 in it last night and seemed to run fine, had a little rpm surge while in gear but I attributed that to whatever is going on with the trans
And just to clarify, when I do the drain & fill x3 am I supposed to drain old fluid and fill with new each time or drain old and fill with new and reuse that fluid for the next two times?
Drain old fluid. Fill with new fluid, run for a little bit, drain (dispose of fluid). Fill with NEW fluid, run for a little bit, drain (dispose of fluid). Fill with NEW FLUID...
However, assuming your tranny is not bone dry, and that the original fluid was correct, and or not burnt, I think you may have a torque converter issue. I would drain your tranny and see what it looks and smells like (burnt?). Take it around the block and see if it shifts better. If not, you may want to look into the converter as the issue. Throwing good money at refilling your tranny, when its mechanical, might not be wise. Its up to you though. A lot depends on the quality of the fluid when it is drained... and or how low you were, if at all.
Seagull Management
If it's an HX it's got a CVT trans not a conventional automatic. It also doesn't take ATF, it takes a special CVT fluid so make sure you figure out exactly what it is you have before you touch the fluid.
Seagull Management
Generally you replace the trans, although in your case it sounds like a bad start clutch, there's a TSB on it(number 02-003) if you're friendly with your local Honda dealership they may print it out for you.
June 25, 2002
Applies To:
1996-98 Civic HX With CVT - All
Shudder, Judder, Surging, Shock, Noise, or Idle Fluctuation
(Replaces 99-068, Surge at Highway Speeds, dated April 11, 2000, and 99-069, Idle Fluctuates When Engine Is Cold, dated December 19, 2000)
SYMPTOM
The vehicle may have one or more of these symptoms:
^ Idle fluctuates between 500 and 1,500 RPM (The fluctuation is more pronounced before the engine reaches normal operating temperature.)
^ Shudder or judder when accelerating from a stop or just before stopping
^ Surging at highway speeds between 2,000 and 3,000 RPM
^ Excessive shock when the engine is cold and you start to accelerate
^ A "coo" sound, lasting about 5 to 10 seconds, after coming to a stop
PROBABLE CAUSE
The problem may have one or more of these causes:
^ TCM control unit programming is too sensitive.
^ The start clutch assembly is worn.
^ The start clutch control valve is contaminated.
CORRECTIVE ACTION
Replace the start clutch assembly, the start clutch control valve, and the TCM.
PARTS INFORMATION
Start Clutch Kit: P/N 06220-P2M-305, H/C 7073448
Honda ATF-Z1 (seven quarts required):
P/N 05200-9001 H/C 6512628
REQUIRED SPECIAL TOOLS
Start Clutch Remover: T/N 07TAE-P4VA120
Start Clutch Installer: T/N 07TAE-P4VA130
Wow those parts alone are over $1,100. What are the chances that replacing the fluid will help the situation. Also DW-1 replaced the Z-1 fluid, is this still safe to use in the CVT? What you posted above said to use Z-1.
I did have a chance to stop and look at the car again and the fluid is light brownish, but somewhat transparent. Also may have had a SLIGHT burn smell to it but if it did you can barely tell.
Seagull Management
Usually the cheapest long term option is to swap in a manual trans (a regular 4 speed automatic isn't really an option unless you swap out the entire cabin wiring harness)
Pretty slim.
I don't understand that bulletin suggesting Z1. Honda has their own fluid for CVTs so I'm confused on that.
kamnamurt
03-25-2014 10:07 AM
sulmer
05-27-2008 07:54 PM
