GSR rear disc swap question/s
My car:
1992 Hatch CX
Stock front disk brakes
Hey...first I've researched all the DIY threads and found a ton of info. I just had a couple questions.
So I just bought the whole rear assembly of a 95 GSR. Plus the brake booster, master, and emergency brake cables.
My question is that for the rear does the whole ABS situation matter, or is that the issue for the front only? Am I good to go to proceed? Do I need a proporting valve for just the rear?
Next...am I going to be alright having stock disc's up front and GSR disks in back?
Thanks in advance!
1992 Hatch CX
Thanks in advance!
Re: GSR rear disc swap question/s
The prop valve works with the entire braking system, not just the rear. There are differing opinions with respect to swapping prop valves.
eG.
For 92-95 civics you do if not correct size. Get a 4040 prop valve. You'd be best to get the bigger front disks too. But you can ride the stock ones for a bit. You don't need the brake booster. Only need the prop valve and either a 7/8 or 1" master cylinder.
Seagull Management
No ABS doesn't matter. Keep the stock 13/16s MC, use a '92 - '93 Civic Si prop valve (stamped 3040)
The rear discs will give you absolutely no braking advantage whatsoever other than reduced brake fade if you actually track your car. I've done this swap before, it's the Integra front brakes that make the difference, and this is where you need to swap the master cylinder with the 15/16s unit and 4040 prop valve (these parts need to come from a '94 - '97 Integra RS, non ABS)
Has anyone tried this:
http://www.summitracing.com/parts/tm...FSho7AodN10ANg
That way you don't have to change out your wheel bearing
Because it comes with a new bearing installed in the assembly. Therefore, all I have to do is take off my old assembly, remove the studs off the new assembly, put my extended studs on the new assembly and put it back on.
I figure this is the best way to do it bc I don't have a press, and in my area it's $60.00 to have them pressed in, and $60.00 for the bearing and I don't have to leave my house.
Hope that makes sense. :)
Now I'm confused, so even if I buy that hub assembly I still have to get the bearing pressed in, or the hub assembly pressed in?
http://www.team-integra.net/forum/11...placement.html
Sorry if I'm nooob'n.
Also I got all my stuff off a GSR so I guess I have to get a non ABS break booster and MC and the proportioning valve from that SI that was stated. What a pain in the ***. Can't wait to do the front.
Crazy Honda Guy
Seagull Management
If you're only doing the rear the CX MC and the '92 - '93 Si MC are the same, all that needs to be swapped is the prop valve. If you're going to swap the fronts later you might as well just wait on the prop valve and swap the fronts and prop valve, master cylinder and brake booster at the same time.
Deetz, I'm starting to think about going the route you're suggesting. It seems like a PITA for basically aesthetics.
94EG8, please don't internet punch me. So if I get that hub assembly, all I have to do is swap the hub assembly? I can pull off my old hub assembly, and put the new one on without having to press anything in? I'm trying not to have to press anything in, I don't have a press and all the stuff seems like a lot of work, I'm just trying to put extended studs on my car essentially and thought about doing the rear disk while I was doing all this work. I feel better knowing that all I need now is a proportioning valve until I do the front. I can get all that other stuff later.
Seagull Management
Just so you're very aware no matter what you do you will need to swap the rear spindles out for Integra units and use Integra rear hub assemblies. If your current bearings are good there's no point in replacing them, simply remove the 32mm axle nut, slide the hub assembly off, hammer the old studs out and hammer the new ones in.
Okay so here's my new plan...
I'm going to drop the rear disc plan for now and keep my drums, put that money into better pads, rotors, and stuff up front.
I'm going to take off my front and rear assembly's off, check my bearings, if they're fine I will keep them on, and put on my extended studs. I guess I really made this more complicated then I should have. Thanks for all the insight and help everyone.
Is the drum assembly hard to get off to put the new studs on?
Seagull Management
No, make sure the parking brake is off, wack the face of the drum a few times between the studs and it should break free of the hub, you may need to back the shoes off but most of the time with a Honda this isn't necessary. If that doesn't work you can thread a couple of 8mm x 1.25 bolts into the holes in the drums to force them off. If all else fails heat the drum around the center hub and continue hitting the drum. Usually they come off without much difficultly though.
mrbigg9032
Suspension & Brakes
21
12-08-2008 08:01 PM
Vero
09-04-2004 04:24 AM
