White smoke help!
White smoke help!
I got a 96 civic dx, when started it smoke a little but when giving throttle it starts to smoke more. So headed to work getting on i throttle it and let off the pedal but when i throttle again a cloud of white smoke shoots out the exhaust. Any help? i changed the head gasket doesn't seem to be over heating. need help on figuring this out its my daily commuter
Re: White smoke help!
What does the oil on your dip stick look like? Is it milky? If so you have a leak from the HG to an oil galley...
Pull your plugs out one by one. Look down each cylinder hole and check the condition of the top of the piston. If the plug and the piston head look brand new, compared to the others, you have a small leak from the HG into the cylinder.
When you replaced the HG did you have the head surface cleaned up, and checked for cracks?
What does your exhaust smell like? Sweet vapor, or fuel?
or possibly a warped head? have the head milled down to spec if it is. otherwise it's not sealing right.
are you losing coolant too? pressurized radiator? those are symptoms of a cracked block or bad hg or warped head.
derek18105
11
11-25-2012 04:19 PM
yoursupahero09
19
06-26-2005 08:31 AM
