Honda B18b block with B16 vtec head problem!
hi, friend got himself a new car, is a Frankenstein conversion on a b18b3 block with a b16b6(i think) vtec head. there is a problem though with the vtec solinoid so we bypassed it to try figure out why its only running to 6500 rpm and vtec not engaging like it should. so we got vtec to work on a switch(just for now to test) but the car is limiting at 6700, could it be that the seller lied and its a b18b3 ecu(because his other civic hatchbacks ecu is completely different and its a original and stock b16 vtec) or a vtec ecu with a problem? or something else?
Any coments welcome
Any coments welcome
I never narc'd on nobody!
Re: Honda B18b block with B16 vtec head problem!
I'm assuming a B18B3 is non-vtec. You're having problems getting vtec to engage because you're running the wrong ECU, which is also probably why it's hitting a low rev limit. Get the proper ECU then try again. Your CEL should be on. Pull the codes.
Man U FTW
Sounds like you're running a non-vtec ECU. Get the proper ECU and it should alleviate those problems...check out/ contact Xenocron, Phearable, J-K tuning, etc and they should be able to hook you up
Thanks alot its going in in the next 2 days for a diagnostic test, checked the codes on the ecu and the ecu is way different going to try run his origional b16's ecu on it
redrix
04-21-2013 01:06 AM
