Idle Problem
Old 11-30-2013, 01:51 PM
Pat_Black's Avatar
Icon6 Idle Problem
Hey guys, so I was hoping someone could help me out. I have a 2000 b16a2 in my 98 hatch and the other day I changed m Idle air control valve bc I was having a issue with the rpm's going up and down really fast when the car warmer up. Also when this would happen and I hit the throttle my car would jerk back and fourth. I changed the iac and also adjusted the Idle screw in the throttle body and nothing has helped. Have any of you guys ran into this issue or heard about it before. Any input would help. Thanks.
Old 11-30-2013, 01:55 PM
boostedteg4dr's Avatar
Default Re: Idle Problem
unplug the IACV.
If it still surges it is not your problem.
plug of all vacuum lines. A vacuum line or the part they are hooked to could be leaking.
Old 11-30-2013, 02:15 PM
Pat_Black's Avatar
I did that and it does stop the surging. As soon as I pug it back it starts again. Is it possible that I have two bad iac valves though?
Old 11-30-2013, 08:11 PM
b20bFourDoorCivicLX's Avatar
In these kind of situations where you've replaced parts and nothings changed, its time to ask for a buddy to come and help assist you or even a mechanic dont drive your car like that.
Old 12-04-2013, 02:06 PM
Pat_Black's Avatar
I was able to fix it myself. Went through and replaced a couple of vacuum lines and it stopped. Thanks guys.
hatch_kidb18b1
08-04-2009 05:27 AM
ilovemyh22
05-06-2009 12:54 PM
averyvm
17
01-17-2007 11:51 AM
wolf3007
03-26-2004 05:06 AM
Metal_SOL
11-19-2002 07:05 AM
Quick Reply: Idle Problem
