Obd2 to Obd1--Do I need both ECUs?
Hello, HT. I previously had a D16Y8 in my 1999 EK (OBD2), and recently swapped in an OBD1 B18C1 (1994 GSR). I had someone do the swap for me. I'm not sure if how OBD conversions work, but it seems like I have 2 ecus sitting in the passenger side of my car. It's kind of difficult to tuck them away somehow since there isn't a lot of room to put away both of these ecus. I noticed that one of the ECUs (the smaller one) has absolutely nothing connected to it but it's being held on by a red clip. Can I just remove that clip and get rid of the smaller ecu? Nooby question, I know.
Technical Hero
Re: Obd2 to Obd1--Do I need both ECUs?
Just guessing you're from CA? If so you won't pass emissions with the one that's plugged in. What is the code on the other smaller ECU?
Check here and post it
http://www.hondata.com/techecuid.html
Man U FTW
Edit: Yes, I'm from Cali haha
Technical Hero
You won't pass with the OBD1 ECU. The other ECU is your stock ECU and can't be used with your current engine. To have a chance of passing you'll need a 96-99 P75 with a jumper harness. However having an older engine in a newer car doesn't fare to well for you either.
Man U FTW
^^I've said it a million times...i'm so glad i dont have to deal with that nanny state bullsh!t. I haven't owned a car that would pass Cali smog yet...
It's a hassle getting cars to pass smog. Saddest part is that smog shop workers aren't required to tell you what's wrong with your car if it fails a smog check
