Electrical issue Please help!
I suck at electrical and I am at my wits end so hoping somebody has run into a similar issue or problem. So I'm going to list everything I have done in order to help diagnose my issue.
September I had issues with car not starting, replaced starter, relay, checked all fuses, ect. turned out it was the clutch switch grommet that broke, replaced that. Car worked fine.
Monday I was working on replacing a leaking clutch fluid line, and after bleeding the clutch fluid I go to start the car hear the starter click once and then nothing, starter would not turn over anymore.
So I am thinking maybe my re-manufactured started went bad... I replaced it still can't get car to start.
Many people said it could still be issues with your clutch switch so I jumped it. Car still won't start. I check all fuses with light tester and all fuses worked accept for starter fuse only lights dimly....
I had a mechanic tell me its my started relay or main relay so I replaced that still same results I'm at my wits end... my only guess is having a grounding issue but it seems like all my grounds are connected as far as i can tell.
Any help would be greatly appreciated.
Re: Electrical issue Please help!
Over a hundred views and no posts, i don't blame you!
Well after more testing it appears the "new" starter is a piece of crap. Wasted so much time on this I hope Parts Authority builds better re-manufactured parts than BAP. At least i know its not my electrical system.
redefsir
19
01-28-2010 08:46 AM
