99 Civic DX - Speedometer Not Working after tachometer installed
Someone please help me. I just installed a Tachometer into my 99 civic Dx and reconnected everything and my speedometer isn't working. It stays at 0. Please help
Re: Speedometer Not Working
Your plugs may not be pushed into the back of the cluster all the way. Check that. We also need more specs etc etc. Pics would help too.
I'll post some pics in the morning. My 99 dx. I installed the tach. It works fine, no speedometer reading on the other hand. I didn't mess with anything besides removing the cluster and wiring the tach to the hood to connect to the tach signal wire. When I reconnected the cluster the speedometer needle stayed at 0 even in 2 gear. I tried checking the plugs behind the cluster and they are fine. Lights,temperature and gas work fine. Just not the speedometer.
No check engine light. I guess I'll go to autozone later to have them check for me. I checked the speed sensor and it's tight and unmoveable, I also checked the fuse and it's fine.
Re: 99 Civic DX - Speedometer Not Working after tachometer installed
Yes i removed the cluster, ran the wire to the tach signal wire thru the firewall. The power cable of the tach to the fuse box and the ground to a piece of metal. It worked when I turned the key to the on position. I said "ok it works" started to put everything back in place when I decided to check the cluster and the tach together and I reved the engine and the tach moved just not the speedometer. It stays stuck at zero.
In general, you need to provide more details if you expect to get any help.
Why didn't you just use the blue wire in the cluster connector? You ran a tach signal wire though the firewall. What exactly did you connect the wire to? How did you connect it?
Where in the fuse box? The dash fuse box?
Where?
It? Speedometer or tachometer? With the engine off?
The speedometer will only move when the car is moving, not when you rev the engine with the transmission in neutral.
I connected the tach signal wire to where it had to go. On the wire with the pill on it on the driver side. I couldn't find it in the harness. A piece of metal near the cluster and steering column. I connected it to The in dash fuse box. The speedometer was the one that didn't work. The tach worked fine. I drove the car and the speedometer still didn't move. The tach did but the speedometer didn't.
I connected to an open prong on the fusebox.
No I only took off the plastic cover to clean it since it was dirty
Post a picture.
This requires removal and reinstallation of the 4 speedometer screws, right?
http://imgur.com/ERlCBxZ
I just removed the 7 clips from the front side.
Last edited by Former User; 03-02-2014 at 08:39 AM. Reason: Fixed picture for display in post
Oh, the clear cluster lens. I thought you removed the plastic printed circuit board.
Anyway, make sure cluster connector B is fully seated. If the speedometer still doesn't work, you need a multimeter to troubleshoot further.
You posted a picture of the dash fuse box but didn't indicate where you tapped into the box for voltage.
