Need help identifying JRSC fitment
Old 03-01-2014, 08:25 AM
conedodger67's Avatar
Default Need help identifying JRSC fitment
Can anyone tell me what Honda D series motor my JRSC was designed for?
The bolt pattern appears to be for a D16Y7, Y8 or SC, but the manifold flange is flat across the top and extended with what appears to be a 2nd gasket imprint above the manifold gasket. I cannot find another picture of one that has this feature. The upper gasket has holes drilled through to the injector holes and there is a casting added with a vacuum fitting at the top, in the center area.
Old 03-01-2014, 09:49 PM
MOTORVATIONS's Avatar
Default Re: Need help identifying JRSC fitment
The '96-00 Civic D-series JRSC kits use the same intake manifold... the one you have pictured appears to have been installed on a '99-00 Civic because the newer cylinder head uses the vacuum accumulator rail across the top of the intake ports and merges it to the brass fitting pointing straight up on the top of the intake manifold. If you are using it on a '96-98 D-series cylinder head, simply use the stock type gasket with the manifold and you will be fine. To clean up the install, remove the brass fitting on top and plug the hole.
Old 03-03-2014, 06:53 PM
Old 03-03-2014, 06:59 PM
Thanks for your help, that's what I needed to know.
Old 03-03-2014, 07:18 PM
crazyhouse2011's Avatar
It's good to see somebody going the supercharger route for once.
Old 03-03-2014, 07:22 PM
ej1b18c1's Avatar
Can't blame people for not wanting to use it because of the limit of power it will put out. I know what you mean though, I would go Vortec if going that route.
Old 03-03-2014, 08:09 PM
Smoother power curve, and no uncontrollable fuel-cutoff-smacking power spike at high revs from a turbo.
Old 03-03-2014, 08:14 PM
ej1b18c1's Avatar
Old 03-04-2014, 10:03 AM
JuggerNaut-CTR's Avatar
Old 03-04-2014, 12:27 PM
Originally Posted by JuggerNaut-CTR
Do you guys ever watch youtube videos of people pushing high boost, large turbos on 1.6s and 1.8s? Huge power spike at high revs. With the same amount of boost/cfm from a supercharger, it would be less violent and more controllable.
Old 03-04-2014, 12:33 PM
Yes I do and dont know what you are talking about...
What is "high boost" and "large turbos" to you?
You crack me up...you think a supercharger is capable of producing the same amount of psi as a turbocharger? A supercharger on 30+ psi hehe. Your funny
Old 03-04-2014, 12:47 PM
talks to himself
CX-Adam's Avatar
Your funny
You're* ::sticks tongue out:: Just fueling the flames over here.
Anyways, you guys should back off ripping on SCs. Some members may get a little sad... (eyes drift to link in sig)
98b16sc
01-25-2013 02:48 PM
Bsharpe
08-10-2010 02:49 PM
tronic
01-07-2008 06:19 PM
project dc2
08-03-2005 05:26 AM
BringIT
12-01-2003 06:28 AM
Quick Reply: Need help identifying JRSC fitment
