Civic/GSR swap - low idle and runs rough
Old 02-21-2014, 06:03 PM
bobbyspradlin89's Avatar
Default Civic/GSR swap - low idle and runs rough
Its a gsr in 95 civic fresh rebuild and when I go to start it, it starts perfect for about 3 seconds then shuts off and I can keep it running with my foot but its rough.
Last edited by Former User; 02-21-2014 at 06:13 PM. Reason: Text edits after moving a new thread
Old 02-21-2014, 06:16 PM
Default Re: Civic/GSR swap - low idle and runs rough
Its also really rich when I make ot run with my foot it's at 10.3 on my wide band please help.
Old 02-21-2014, 06:17 PM
I never narc'd on nobody!
NotARaCist's Avatar
What ECU are you using? Is the CEL on? Does it work? Have you checked mechanical and ignition timing?
Old 02-21-2014, 06:21 PM
Its a virgin p28 stock map sensor stock injectors at the moment and ues its dead on far as thw timing light shows. But its weird I can start it and it will fire up fast run good for like three seconds then curs off.
Old 02-21-2014, 06:22 PM
Only cel is for vtec pressure switch code 22
Old 02-21-2014, 06:28 PM
NotARaCist's Avatar
You're using the wrong ECU, and the car isn't running correctly. Imagine that!
Get a GSR ECU.
Old 02-21-2014, 06:29 PM
Update I've replace ect, tps, swaped map sensors, three different distributers , I've check contintuity on every sensor there all in correct spots on ecu
Old 02-21-2014, 06:30 PM
Car ran fine off p28 with ls vtec ?
Old 02-21-2014, 06:32 PM
Even with p28 it shouldn't dump that much fuel should it? I've tried ls ecu also with no luck.
Old 02-21-2014, 06:47 PM
The plugs drip of fuel when pulled just after a couple starts.
Old 02-22-2014, 04:20 AM
Bump
Old 02-22-2014, 04:51 AM
Eg.ls.turbo's Avatar
P28 isn't goin to run a stock gsr manni. Gsr manni has butterflies in which the p28 doesn't have.
Old 02-23-2014, 04:04 PM
Its a Victor x manifold. The whole setup up is b18 c bottom end with manly rods, wiseco 10.1 pistions, sleeved block 81.5 bore built b16 head with crowler stage 2 cams valves and springs and retainers. With Victor x manifold with thermal intake gasket and cometic head gasket precision 62/62 turbo ect. Car starts rich and won't idle and will not run until its warm then it will idle but still rich and will bog down and cut off when trying to move it. Bit it has stockap sensor and exu amd injectors till I go to have it tuned . So please help ...
Old 02-24-2014, 11:55 AM
Bump
Old 02-24-2014, 01:22 PM
NotARaCist's Avatar
Oh, so there's a bunch of details you didn't give us in your first post? Read the rules sticky. Everything you just posted should have been in your original post!
Tow your car to a tuner. End of discussion, end of story.
Old 02-24-2014, 07:46 PM
Miguel613ekb18c's Avatar
Maybe a leaking injector
Old 02-24-2014, 08:38 PM
NotARaCist's Avatar
OP seems to think a stock P28 can run a boosted, cammed, bored motor. Stop, right the **** now. You've probably already washed the cylinder walls and fucked the motor up, but tow it to a tuner and let them unfuck what you've already messed up.
Old 02-24-2014, 08:49 PM
RESIDENT
TypeRfit's Avatar
What size injectors are you running?
Old 03-01-2014, 05:25 PM
Stock injectors off my b16 and it womt run long enough yo hurt it I hope and I already talked to shuee he said it sjould run on stock map and he can't tune it till its running normal I'd be wasting my rime towing it down there.
Old 03-01-2014, 06:00 PM
KashAddikt's Avatar
I'm having a similar issue with my swap except my idle problem only happens at a red light. It be 1000 for about 20 sec then it'll drop but I have a chip gsr ecu.
Old 03-02-2014, 05:41 AM
Yeah mine is all the time it will start gine for about three seconds and it will cut straight off ?
Old 03-02-2014, 06:57 AM
KashAddikt's Avatar
Oh nah mine last a little longer then that but I may have exaggerated a bit but I thought it was the obd2 sensor thing on the back of the throttle body. So I got a new one and it didn't change anything. You may have to clean the throttle body with the carbon cleaner I think it's called. That's what I gonna do and I'll let you know if it works. And try adjusting the idle. It may be too tight to where no air is getting in.
Civic HX 121
21
11-07-2014 02:55 AM
mikess
05-06-2010 05:24 AM
msinsky14
01-31-2009 11:59 AM
M.A.R.C.
03-20-2006 07:36 AM
lopey
08-21-2002 01:46 PM
Quick Reply: Civic/GSR swap - low idle and runs rough
