96 civic sedan - manual to power window conversion
I got the front 2 working and matched the driver rear door wiring to driver master switch and nothing. Also the 2 rear doors got the same color wires on each side for the window switch and only one set of same colors on the driver master switch. Do the rears need a relay? I dont want to use a floor harness
Re: 96 civic sedan - manual to power window conversion
Insufficient information in first post.
Recipient car - 96 Civic DX sedan?
Source (car, year, trim, etc.) of donor wire harnesses?
Which donor wire harnesses did you install (door, dash, floor)?
There's one relay for all the power windows.
What's the alternative?
Fish Twig
Take a look at the wiring diagram in the honda repair manual.
edit: http://s78.photobucket.com/user/tony...psc2921a65.jpg
Both are 96 and im using ex complete doors on a dx. Iv done the method in 2 of my hatches by using the method without the floor harness by using direct power, but on the 4 door im trying to figure out how to control the rear using driver master switch. I got the fronts working but cant get the rears to work off the master switch. I can directly give power like the fronts but only work of rear switches, I want to be able to control them from driver master switch also
Propulsion
17
03-05-2016 03:42 PM
Iloveyourhonda92
10-18-2014 06:01 PM
TNight
05-25-2014 04:49 PM
wlmullen
07-08-2011 08:14 PM
dfx3232
05-05-2007 07:13 PM
