1995 Del Sol Dies after crank
Hey Honda tech'ers,
I have a 1995 1.6L SOHC VTEC Del sol that dies after releasing the key from the start position. The car was running great last night. It will continue to turn as long as the starter is engaged, but when disengaged it dies immediately.
Last weekend I replaced the thermostat and cleaned the idle air control valve - it drove fine for 4 days afterwards, but in case there are near by sensors I may have knocked loose.
Any ideas what may be going on? Ignition switch maybe?
Re: 1995 Del Sol Dies after crank
My only hesitation is I replaced the ignition switch about a year ago. Is it still the most likely point of failure given its new-ness?
Also I'm noticing the ignition switch is often sold as a unit with the lock cylinder - if the car runs in the 'start' position than I shouldn't need to purchase the whole unit, correct?
Mitchel Perkins
07-24-2017 07:32 AM
Tk42
03-03-2012 05:51 AM
prime-R
03-10-2011 10:37 AM
gilligan354
05-07-2007 07:49 AM
