97 Civic vacuum leak problem after removal of cruise control
i have a 97 honda civic with the y8 motor. when i had the engine out rebuilding i removed the cruise control. well i noticed the other day the vacuum line that went from the cruise control to the back side of the intake manifold is open. but when i plug it with my finger the engine wants to die. should i plug the hole then re-time the engine. since when it was put back together it got timed with a vacuum leak? any help would be great.
Re: 97 Civic vacuum leak problem after removal of cruise control
thanks ill give it a try. to reset the ecm i can just pull the fuse and wait ten minutes or is it better to disconnect the battery for a while?
attz0r
02-18-2014 03:29 PM
1wiperDude
11-14-2008 09:21 AM
