93 civic stArts then shuts off
The car was idling the stalled off like u turned the key off. When I restart it starts then dies.not like out of gas.i checked the fire at plugs the main rely,injector pulse.and fuel pump and all seem ok.when I un hook map sensor it starts then acts like out of fuel then dies.when I unhooked the injectors it will also run a little better then shuts down after a few seconds like out of fuel.when I hook back up the injectors it will start then strait off.not like out of fuel maby the PCM is bad but don't know. Can someone please help.
Re: 93 civic stArts then shuts off
Check your gas lines? did you take the whole fuel pump out an check it out? strainer bag may need to be replaced.. maybe even bad fuel filter..
Check your grounds. It honestly sounds like you're just shorting out, or the circuit is being broken at the main relay, so that would be my first point of digging, by checking the grounds to everything.
Luke 91 ef
01-24-2013 10:40 AM
