Can I use a d16y8 head with a d16y7 ecu?
Old 03-01-2014, 06:01 AM
raider1qaz's Avatar
Default Can I use a d16y8 head with a d16y7 ecu?
Can i use a d16y8 head without hooking up the vtec? i have to oreder the ecu si i wanna run the y8 head with y7 throttlebody and intake manifold just for now ,can i do that?
Old 03-01-2014, 06:24 AM
Technical Hero
HondaPartsHero's Avatar
Default Re: Can I use a d16y8 head with a d16y7 ecu?
yes
Old 03-01-2014, 06:37 AM
raider1qaz's Avatar
it wouldnt run different?or act up?thanks for the reply
Old 03-01-2014, 06:43 AM
Technical Hero
I mean it won't run optimally but it'll run fine as long as you use the intake manifold and TB from the Y7.
Old 03-01-2014, 07:31 AM
raider1qaz's Avatar
once i get the y8 ecu must i use the y8 intake and tb? its cause on my y7 i have a cold air intake
Old 03-01-2014, 07:33 AM
raider1qaz's Avatar
old set up in car new set up out of car
Old 03-01-2014, 07:50 AM
Fish Twig
tony_2018's Avatar
vtec won't kick in so you won't have a problem, now if you tried to use a vtec controller to enable the vtec than that is where your car starts to run like ****.
Old 03-01-2014, 07:51 AM
Technical Hero
Yes because the idle air control valves are different. You'll also have to wire up VTEC and knock. Are you sure that's a y8 head because it's not a y8 manifold, more like a z6.
Old 03-01-2014, 10:51 AM
raider1qaz's Avatar
How can I check if its a y8?
Old 03-01-2014, 10:57 AM
raider1qaz's Avatar
Do I need a 96 ecu cause I have a 96 civic with 96 wireharness or do I need a 99ecu cause the head is off a 99 civic
Old 03-01-2014, 11:20 AM
raider1qaz's Avatar
Just checked its a 1999 ex d16y8 head
Old 03-01-2014, 11:27 AM
tlarimer's Avatar
That's a Z6 intake manifold though
Old 03-01-2014, 11:29 AM
tlarimer's Avatar
Use the ECU for your year car, which is OBD2A. 99-00 Civic's are OBD2B, so unless you're planning on changing the engine wire harness to OBD2B as well, get a 96-98 OBD2A ECU.
Old 03-01-2014, 01:28 PM
raider1qaz's Avatar
ya its a z6 intake, i think its a manuel on tho and i have an automatic(for now)
Old 03-01-2014, 02:36 PM
Fish Twig
tony_2018's Avatar
would be easy to help if you provide alot of info in your first post.
Old 03-01-2014, 03:52 PM
Technical Hero
-use your harness (or find a 96-98 ex harness for plug and play)
-add vtec, knock, and IACV 3-2 wire conversion
-if you use the ex harness you'll have to manually wire in the 2nd 02
-put your cars intake air temp sensor into your intake arm or convert to the round style on your z6 manifold
Old 03-01-2014, 08:14 PM
raider1qaz's Avatar
Default Y8 block/Y7 head/auto transmission - any issues with replacing Y7 head with Y8 head?
i have a y8 block with a y7 head
i just bought a y8 head so soon ill have a full y8
The car is an automatic (yes i know i need to go stick and i will as soon as i get the money)
any issues? thank you
Last edited by Former User; 03-02-2014 at 05:49 AM. Reason: Refocus thread on tech
Old 03-01-2014, 10:03 PM
Stancetard Hate Monger
eghatch9295's Avatar
Default Re: How to get the most out of an automatic vtec?
the problem you'll run into is that you can't run the y8 vtec ecu with your setup. the tcu is integrated in the ecu, and the y7/y8 transmissions are not the same. unless you convert to 5 speed or swap transmissions, no vtec for you.
Old 03-01-2014, 10:24 PM
raider1qaz's Avatar
why not?ive done all my homework on the swap, ive ordered the p2p obd2a ecu already and got all the connections i need and wires to extend the wires,the other post i made noone said i couldnt
Old 03-01-2014, 10:29 PM
raider1qaz's Avatar
i think the z6 intake is for a manual transs, but i have a auto, what can i do? i ask cause you seem to know so much about this
Old 03-01-2014, 10:36 PM
I never narc'd on nobody!
NotARaCist's Avatar
The TCU is integrated into the ECU. The TCU controls the transmission. It expects the gear ratios for the transmission that came originally equipped with that ECU. An EX ECU cannot properly control a DX/LX transmission, and will throw a CEL because of it. A DX/LX ECU cannot properly control an EX transmission, and will throw a CEL because of it. For autotragic Civics, you HAVE to match the ECU to the transmission.
Old 03-01-2014, 10:52 PM
raider1qaz's Avatar
is there a way to check the trassmisson and see what model it is?the previous owner rebuilt the whole engine and had a full y8 but never put the head cause it was for the wife, anyway is there any marks on the trassmisson thatll tell me what kinda it is?
tlarimer's Avatar
Z6 auto and manual use the same manifold. Y8 has two manifolds, one for auto and one for manual. If it was me, I'd get a Y8 auto manifold. I actually have a 99 Y8 auto manifold on my 99 Y7 civic and have had no issues since I put it on 1.5 yrs ago, even passed CA emissions testing with it
Old 03-01-2014, 10:55 PM
NotARaCist's Avatar
If you clean it off, there should be a casing code on it somewhere. If memory serves, it'll either be an A000 or B000, or something similar. Assuming your CEL isn't on right now, and you're running a DX/LX ECU, you have a DX/LX transmission.
Old 03-01-2014, 11:58 PM
y7 and y8 injectors are different as well, grab the y8's
Quick Reply: Can I use a d16y8 head with a d16y7 ecu?
