dash wiring ??
dash wiring ??
anyone know anything about dash re-wiring for the entire dash including the gauge cluster on a 99 civic si?? also headlight re-wiring. i got all the harnesses and gauge cluster i just have no clue on the whole harness thing and i can't seem to find any info anywhere. honda quoted me well over a grand for the work. lookin to try this weekend. would appreciate any info.
Modified by bluecivic05 at 2:57 AM 6/15/2006
Re: dash wiring ?? (chartinael)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chartinael »</TD></TR><TR><TD CLASS="quote">ok ... so what exactly do you need done ... what model do you have ... what exactly needs to be done?</TD></TR></TABLE>
going to pull out the dash, unplug the main dash harness, and install the new dash harness and gauge/climate sub harness. also put the oem gauge cluster in. (there is just a generic one in there now.) i have a 99 civic si (em1).
Re: dash wiring ?? (bluecivic05)
there is nothing you need to do ... just unplug existing harness and replace with new harness .... I just don't understand why exactly you need a new harness and a new gauge cluster?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chartinael »</TD></TR><TR><TD CLASS="quote">there is nothing you need to do ... just unplug existing harness and replace with new harness .... I just don't understand why exactly you need a new harness and a new gauge cluster?</TD></TR></TABLE>
because the idiot who had my si before me spliced up my dash harness because the interior got stolen. not everything on the dash works, and the gauge cluster is just a generic one. i can't jsut plug in the new gauge cluster, there are no plugs that match the oem si cluster. i'm just tryin to get everything back to normal. only had the car for 6 months. the last thing left to do to make the car "normal" is the re-wiring.
ok, understood .... harnesses are outrageously expensive as far as honda goes ... so your best bet is a junkyard. you can take out any dashboard 2D/3D/4D and take out the dashboard harness (of course ... 99-00) it has all the connectors you need. the rest is simple ... it is best to take a buddy to the junkyard because to take out the dashboard harness you need to take out dashboard and it is easiest when done with a friend ...
hey man i re-wired under my dash and headlights and motor, and the list goes on any way if you have any question i will answer if i can. pm me of whatever
benn2k
12
02-19-2011 03:10 PM
sohcdestruction
02-14-2008 12:36 PM
