bad starter?
1 Post
bad starter?
ok so in the searches i came across, everyone gives examples of there starters an everyones clicks so they get the ole' "battery, alternator" thing.. well mine doesnt click or anything, but i can pop the clutch to get it started.. "good thing i live on a slanted driveway"... but yeah i turn the key an all the lights stay on, no dimming anywhere, could this be starter?? it doesnt turn or click or nothing, just straight nothing...
1 Post
Re: bad starter? (sasser43)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sasser43 »</TD></TR><TR><TD CLASS="quote">If you can still pop your clutch to get it started, then yes its most likely the starter</TD></TR></TABLE>
so i just put brand new starter in, an same thing i turn the key an nothing happens... i popped the clutch an unplugged the battery, car stayed on an remained normal at idle.. i checked the alternator an its getting the right volts an so is the battery.... what im wondering is, what engages the clutch..??
Re: bad starter? (JDM_SOHC)
Could be the power wire running to the starter, could be the signal wire running to the starter, could be the switch on top of your clutch pedal(which wont allow the starter to crank, unless the pedal is depressed).
These are all things that should be checked before paying for a new starter.
1 Post
Re: bad starter? (Slopoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke »</TD></TR><TR><TD CLASS="quote">Could be the power wire running to the starter, could be the signal wire running to the starter, could be the switch on top of your clutch pedal(which wont allow the starter to crank, unless the pedal is depressed).
These are all things that should be checked before paying for a new starter.</TD></TR></TABLE>
thats exactly what was wrong... gotta .02$ paper clip jammed'r up in there, elec taped her together, shes startin better than ever with that new starter on there lol... thanks guys..
Re: bad starter? (kwakwax21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kwakwax21 »</TD></TR><TR><TD CLASS="quote">yep, it's either the starter or battery. i was just working on a car that had the same problem today, ends up being the battery. car didnt crank or turn or nothing.</TD></TR></TABLE>
dude, reread the post.
It wasnt the starter or the battery.
1 Post
It wasnt the starter or the battery.</TD></TR></TABLE>
lol some are slower than others...
memorybox
01-26-2007 01:26 PM
JDM As It Gets
12-15-2006 11:52 AM
rukawa1one
05-29-2005 07:06 PM
