Hole in my oil pan
Hole in my oil pan
I bought a junkyard d16y8 and installed it. I thought it was a dent on the rear of the oil pan, but as soon as I filled it with oil it started leaking. It is probably from coming in contact with a bolt on the subframe just behind it, either in an accident or when the junkyard pulled it. my question is how do I fix it? Is the oil pan pressurized, is this something that will have to be welded, or can I just quick steel it?
I don't get it, if it's dented, it's obviously not holding the proper ammount of oil, and it's leaking and crap..why not juts by another oil pan? They should be cheap enough for the D series...
Stewie
Welding / Fabrication
11-09-2005 08:38 AM
