Calling Honda Gurus, please help.
Old 04-27-2006, 04:01 AM
hondasport2000's Avatar
Default Calling Honda Gurus, please help.
I have just done an H22 Swap (OBD1) into this car. I made the harness myself, and stepped it down to OBD1 from OBDIIB.
I have an engine light. A code 9 (CYP Sensor) has occured. I have testing my wiring. Tested for resistance at the orange and white out of the distributor to get 389 ohms (within the spec of the factory rating of 350-700). I then tested for continuity from the orange to ground, and white to ground AT THE DISTRIBUTOR end and come up with negative. I've then tested for resistance at the ECU plug (with the distributor plugged in of course) and come up with 388 ohms, and proceeded to check for continuity to ground and come up with NEGATIVE.
I have then used the 'snap on' scanner (Modius using Advantage PLUS for sensor check), and did my sensor function test for resistance, pulse, frequency, KOEC, within-spec, at both the distributor and at the ECU. All tested have yielded results WITHIN sensor limitations and ranges.
I've as well had TWO other H22 swapped cars here that I have taken both the distributor and ECU from this car and placed on BOTH other cars to only NOT get an engine light. Of course, I've then the ecu and distributor from BOTH other H22 cars (which run with NO engine lights) in this car and have yielded an engine light with both ECU and distributor (ironically enough, a code 9 ). As of an hour ago, the valve cover came off, the crank set to TDC (through the inspection hole between the tranny and block), and the cam gears have both been noted to be BANG ON in timing marks. Ferarri's aren't timed up this well.
On a side note, YES the grounded sheilding wire is still run through the harness, and is still connected. As well, two wires have been run from directly at the distributor to the ECU directly still throwing a CODE 9 when running. Inspection of the ECU plug has showed a bit of corrosion, so the entire plug was replaced (all wires cut, new plug soldered and taped into the harness, and of course, Mr. CEL 9 has come back to visit.
Any suggestions? i am running out of things to try, and am getting pretty frustrated..
Old 04-27-2006, 06:28 AM
IHateJDM's Avatar
Default Re: Calling Honda Gurus, please help. (hondasport2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondasport2000 &raquo;</TD></TR><TR><TD CLASS="quote">As of an hour ago, the valve cover came off, the crank set to TDC (through the inspection hole between the tranny and block), and the cam gears have both been noted to be BANG ON in timing marks. Ferarri's aren't timed up this well.
that inspection hole is there for when you're using a timing light to set your ignition timing, not your cam timing. To make sure the crank is right on tdc, there is a dot on the gear behind the crank pulley that lines up with a mark on the block.
Old 04-27-2006, 08:43 AM
Luserkid's Avatar
Default Re: Calling Honda Gurus, please help. (IHateJDM)
What year car is it? OBD1 or OBD2? If its obd2 you ran the crank and cam sensors straight to the ecu from the dist right? (you didnt really say which wires you ran).
What i would do is try swapping out the harness you made with one of the other cars and see what happens. If it throws a code then it might be the motor, if it doesnt its that harness. You tried the other cars ecu and dist. in the car your working on right? What happened?
Old 04-27-2006, 09:02 AM
Default Re: Calling Honda Gurus, please help. (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">
that inspection hole is there for when you're using a timing light to set your ignition timing, not your cam timing. To make sure the crank is right on tdc, there is a dot on the gear behind the crank pulley that lines up with a mark on the block.</TD></TR></TABLE>
cam timing has been checked using the crank pulley to line up. The cam gears are right on as well.
Modified by hondasport2000 at 4:14 PM 4/27/2006
Old 04-27-2006, 11:14 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">What year car is it? OBD1 or OBD2? If its obd2 you ran the crank and cam sensors straight to the ecu from the dist right? (you didnt really say which wires you ran).
What i would do is try swapping out the harness you made with one of the other cars and see what happens. If it throws a code then it might be the motor, if it doesnt its that harness. You tried the other cars ecu and dist. in the car your working on right? What happened? </TD></TR></TABLE>
The car is a 2000 civic obd2b converted to obd1 in order to run the jdm obd1 h22a.
Swapping harnesses may be the only thing left to try. ECU's and dizzys from other cars were tried and all threw code 9. But the ecu's/dizzys worked fine in those cars.
Old 04-28-2006, 04:22 AM
bump
Old 04-30-2006, 02:50 PM
Default Re: (hondasport2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondasport2000 &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
Old 05-01-2006, 06:30 AM
any suggestions guys&gt;?
Old 05-01-2006, 06:46 AM
IHateJDM's Avatar
did you try swapping harnesses yet?
Old 05-01-2006, 06:56 AM
Havent been able to track one down yet... But would it make a difference since the problem is dizzy related and we tried running the wires from the dizzy directly to the ecu (completely bypassing the harness)?
Old 05-02-2006, 02:55 AM
Old 05-03-2006, 05:19 PM
Anyone able to suggest something? We have tried everything we could think of and can't figure out what is going on.
Old 05-04-2006, 06:37 AM
Jayrayk
01-13-2019 06:27 PM
aviator.sm
Engine Management and Tuning
07-26-2018 12:10 PM
sc00te12d00d
12-11-2003 09:01 AM
Krayzielix
02-11-2003 10:10 PM
Quick Reply: Calling Honda Gurus, please help.
