Primary O2 sensor. How do the wires in the plug go?
H-T White Ops
I ripped the plug off the primary O2 when I pulled the motor. The wires and pins are still there, and I have the plug. I don't know where each wire plugs in though in the plastic plug. There are 4 holes in the plug.
The helms manual is worthless in this case. It shows the color of the C123 plug that goes TO the O2, but has nothing on the color wires coming off the sensor. Any help?
Re: Primary O2 sensor. How do the wires in the plug go? (IslandSi)
look at the other other end that it plugs into on the engine harness. folllow it from there. Should be pretty straight forward.
H-T White Ops
Re: Primary O2 sensor. How do the wires in the plug go? (Ls_V_TurboSi)
Wire colors don't match up.
I'm gonna guess that the two black wires are for the O2 heater and it really doesn't matter which one goes where. Now for the green and white, with the two black wires on the bottom, which wire goes where? Take a look at this little paint drawing I did. This is looking at the plug with the pins facing you. Which one's right?
godluvstegs
12-15-2010 07:08 PM
