b16a2 swap in EG work in an EK???
My friend is selling a swap thats on his EG right now. Its currently running a OBD1 p72 ecu. What would it take to get it on my 1996 civic? I know for sure i would definately need the jumper harness obd2a to obd1 to run the ecu. what other mounts do i need and type of shift linkage. any other little things i might need?
thanks in advance!
thanks in advance!
Re: b16a2 swap in EG work in an EK??? (pinoyboy204)
Use an Integra (or the one you are using in your EG) or Si shift linkage.
Driver side - Use driver side mount bracket from the 99-00 Si: 11910-P30-000. This piece bolts to the block below the cam gears. Reuse the civic studs. Also, use all other civic parts at this location.
Rear tranny - Use rear tranny mount from the 99-00 Si: 50827-S04-N10. Use the stock civic rubber mount.
AC Bracket - Use the ac bracket from CRV: 38930-P7J-000, and reuse the civic stud and rubber mount. Integra piece is similar but won't work.
Front tranny bracket - Use integra piece on the tranny but civic stud and rubber mount. Integra stud and rubber looks the same but won't work.
Upper tranny mount - Use all the civic pieces.
Re: b16a2 swap in EG work in an EK??? (BlueIntegraBoy)
thanks for the info!
btw, for the wiring should i leave the motor obd2 or go with obd1? what has less wiring to do??? please let me know!
Re: (professor poon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by professor poon »</TD></TR><TR><TD CLASS="quote">nah, buy my obd2a p72 and keep the motor obd2. Perfect! lol</TD></TR></TABLE>
But it's running the wrong ECU in the first place
Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">But it's running the wrong ECU in the first place</TD></TR></TABLE>
yeah, meaning the motor is obd2, running on an obd1 ecu. So my obd2 ecu is perfect... Did I misinterpret something?
yeah, meaning the motor is obd2, running on an obd1 ecu. So my obd2 ecu is perfect... Did I misinterpret something?</TD></TR></TABLE>
He shouldn't be running the P72 with the B16 in the first place. He can use an OBD2 P30 or convert it to OBD1 and use a chipped P28 or P30.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">He shouldn't be running the P72 with the B16 in the first place. He can use an OBD2 P30 or convert it to OBD1 and use a chipped P28 or P30.</TD></TR></TABLE>
oooh I totally overlooked the part about it being a b16. you're right.
Re: (pinoyboy204)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinoyboy204 »</TD></TR><TR><TD CLASS="quote">I heard that the 99-00 ex (Si) motor mounts work w/ b-series engine as well. can anyone confirm this? </TD></TR></TABLE>
Dude, I wrote the mounts you need in the second post
siffredi
04-19-2006 05:39 PM
atmosphere
04-19-2006 02:30 PM
