Now i really need help.
when the throttle rotates the rotor on the throttle body the cable protector is getting stuck between the throttle rotor and the cable. just cut the black nipple looking thing off and your good. i had the same problem.
Re: (2000HondaSi)
everything looks good in my opinion. you may just want to replace the throttle cable. They arent expensive. Theres a chance it could be fraying somewhere from the pedal to the throttle body.
http://www.hondaautomotivepart...PEDAL
$15.62
$15.62
Re: (doublejz)
what year?
96-00 Civics had a recall on the floor mats. The gas pedal would sometimes get stuck because the mat would slide up.
Honda will install a peg into the floor and give you a new drives mat with a gromet to keep it in place.
As for the Clutch adjustability there is probably air in your clutch line. So you can bleed the clutch just as you bleed brakes. As for tranny fluid I suggest Just go and buy regular 10w-30 oil and Flush it atleast 3 times and shift through all gear before bieng done.
do yall not see the broken nipple on the cable protector, thats the problem as i said before seeing the pics. it slides down the cable and gets caught between the throttle rotor and cable. just snip it off.
Re: (2000HondaSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000HondaSi »</TD></TR><TR><TD CLASS="quote">This guy is right the rubber is torn or something. the dealer will fix it.. it better be free. and the floor mats that **** is superglued to the floor doesn't even move.. that can't be the problem.</TD></TR></TABLE>
Floormat is not superglued to the floor in any of the 6 hondas I owned.... How else do you clean under them when washing the car?
Re: (2000HondaSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000HondaSi »</TD></TR><TR><TD CLASS="quote">dude not literally superguled but you know what i mean right... it's hard pulling it out.. there's a hole in the floormat and a little piece of metal holding it.. right by the seat you can't see it though.</TD></TR></TABLE>
that only means your car was updated with the recall.
move onto the cable then.
dustywebber
07-10-2004 09:04 AM
