sticky throttle body
lately when i start my car (especially early in the morning) the gas pedal seems stuck. i pooped the hood and my throttle body seems a little sticky. i've already cleaned it out and still it's the same thing. ireally am not sure on what to do, i would like to correct the problem before i force it and my cable pops.
Re: sticky throttle body (philosofy1)
Is it stuck close or stuck open?
Stuck close - Turn the stop a little to keep it from slamming itself stuck.
Stuck open - try loosening the throttle cable so it closes fully then do 1 turn out.
Re: sticky throttle body (Luserkid)
it's sticky when close. i can start the car, it'll idle fine, but when i go to give gas thats when it's stuck.
Re: (civic_driver)
Hey Philosofy1 i have that same exact problem. but mines not only when i start it in the mornings, it does it like when i come to a stoplight and when i give it some gas i kinda have to give it a little kick to get it unstuck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_driver »</TD></TR><TR><TD CLASS="quote">there's a little screw under the throttle body plate.. screw in some more so that it keeps the throttle plate a not so tightly gripped against the throttle body</TD></TR></TABLE>
but ima try that to0 see if it helps
Re: (M2nR22)
well i actually went out and tried to fix it tho i didnt touch the adjusting screw that makes the TB stop. instead i adjusted the throttle cable a bit (since it was kinda lo0se too) and it worked. i went out for a drive and no sticky throttle for me anymore
Try it
Try it
Re: (M2nR22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2nR22 »</TD></TR><TR><TD CLASS="quote">well i actually went out and tried to fix it tho i didnt touch the adjusting screw that makes the TB stop. instead i adjusted the throttle cable a bit (since it was kinda lo0se too) and it worked. i went out for a drive and no sticky throttle for me anymore
Try it</TD></TR></TABLE>
thanks, i'll try.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr cx hatch »</TD></TR><TR><TD CLASS="quote">fuel service + injector flush.. and clean out the throttle body with intake cleaner.. </TD></TR></TABLE>
fuel service and injector flush has nothing to do with this.
and my trottle body is cleaned, still problem persists.
thanks, i'll try.
Davis Photography
Sorry to bring up a dead thread.
What size is the bolt for the Throttle adjustment screw? the one under neath the throttle.
thanks.
-Drew
P.S. when I went to clean it the inside seemed to have a oilyish black residue inside the intake maifold.
could i spray wd-40 to help loosen up the butterfly valve inside the throttle body?
thanks.
-Drew
Re: sticky throttle body (DrewMD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrewMD »</TD></TR><TR><TD CLASS="quote">Sorry to bring up a dead thread.
thanks.
-Drew
could i spray wd-40 to help loosen up the butterfly valve inside the throttle body?</TD></TR></TABLE>
yea, you can use carb cleaner...i would take the Intake manifold off and clean it real good..you can prob even use simple green...let it dry up and if the TB still gets stuck...yea, maybe try a bit of wd40..
thanks.
-Drew
