Looking for Honda-Tech for some quality help!!!!
I just put a D15b Vtec motor into my 1992 Civic Hatch. I am getting a error code for my TPS sensor. It is also obvious because when I floor it in second gear, it will bog out/surge on me and cuts fuel. I need to know what I can do to adjust/fix this problem. I also have a loose plug for my IAVC plug yellow/black blue/yellow wire. I can't find where it needs to go. ANY HELP would be greatly appreciated. Thanx
Fighter.
Fighter.
In a Junkyard near you.
There is the purge control, intake air temp, and IAC plug and they are all the same style plug. They are all in the same reigon you just need to track down all three.
What code is it giving you exactally? Did you swap the distributor with the new engine?
Re: (MooGoCow3)
I'll find out what codes its giving. We just used the distributor that was on the new motor.
Do you know where I can find a color corridinated chart for those wires? THanx
lshatch1.8
12
05-06-2006 04:17 PM
