POWER STEERING??
Re: POWER STEERING?? (Muttly)
I HAVE NO POWER STEERING AND I THINK ITS JUST FINE DEPENDIN ON WHAT SIZE TIRES AND RIMS YOU HAVE TOO THAT WOULD MAKE A DIFFERENCE
I DON"T KNOW WHAT WE'RE YELLING ABOUT!!! while you're cruisin down the street about to turn, put it in neutral and turn off the car. Your power-steering will not work, so you can figure it out for yourself what it feels like...
Re: POWER STEERING?? (lazybrown187)
you won't notice much of a difference when the car is moving. people remove it to get rid of unwanted weight and to clear the engine bay out some more. it's also said that you gain some horsepower but i'm sure it's nominal. just make sure you get a manual rack.
Re: POWER STEERING?? (jdmwannabe3)
the steering rack from a non power-steering car. i've heard that you can wear something down on your power steering rack if you take out the power steering. and if you don't know what a rack is then go to http://www.howstuffworks.com and search rack and pinion.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muttly »</TD></TR><TR><TD CLASS="quote">you won't notice much of a difference when the car is moving. people remove it to get rid of unwanted weight and to clear the engine bay out some more. it's also said that you gain some horsepower but i'm sure it's nominal. just make sure you get a manual rack.</TD></TR></TABLE>
Don't take this for absolute truth, but I've HEARD something about a P/S rack can be used without p/s by looping the line back on itself or something...?
Re: POWER STEERING?? (professor poon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by transpar_nt »</TD></TR><TR><TD CLASS="quote">1) Remove the power rack and install a manual one. The big downside to this option is that the manual racks need more turns of the wheel from lock to lock. This is great in a semi but sucks in a car that is supposed to be fun to drive.
2) Loop the lines. This can be done different ways or even just have them capped off, but the method that's the easiest on the rack and your arms is to loop it all with an overflow tank of sorts. Basically fluid is left in the rack to keep things moving smoothly, and the reservoir is used to allow fluid/air to move freely so the pressure doesn't make it difficult to turn the wheel. HT member Padawan has been selling these kits for a while and I've yet to hear of a dissatisfied customer. The only reason I haven't bought his kit yet is because he won't ship to Canada, as you can see near the end of his thread:
https://honda-tech.com/zerothread?id=563116
there, i did your homework for you.
Its not bad i have 95 hb and its ok when ur moving but when u are idle its stiffer. U get used to it... i drive mine like nothing, but if someone else tries to drive they have trouble but it might just be my muscles. The key to it it accelerate as u turn makes it 100% easier
parking lots, parallel parking, and quick maneuvers at slow speeds will be your worst enemy. i got use to it, but i still can't parallel w/o power steering, it takes like 5 min rofl
moualu
47
12-15-2020 12:31 PM
mikej94civex
14
02-12-2010 06:31 AM
dELfONiK
03-09-2007 12:14 PM
